  • Nick Collings 6 posts 26 karma points
    Apr 12, 2010 @ 15:25
    Nick Collings
    Markup Validation of Contour forms
    Ive been adding Contour forms in both the Richtext editor and the template and both are causing markup validation errors. The problem is the default stylesheet for the form is included in the embed as follows:
    <link href="/umbraco/plugins/umbracoContour/css/defaultform.css" rel="stylesheet" type="text/css" />
    Since the embed is always going to be in the <body> tag and you can't have <link> tags anywhere else except within the <head> tag this will always be invalid. I've been checking it using the W3C Validator (http://validator.w3.org/) and the markup is XHTML 1.0 Strict.
    Does anyone know if I can fix this?
    Thanks, Nick
    Umbraco 4.0.3, Contour 1.0.7, ASP.NET 3.5, Windows XP SP3, IIS 5.1
  • Comment author was deleted
    Apr 12, 2010 @ 21:32
    Hi Nick,
    If you add a runat="server" to your head then it will be aded there.
    Or you can disable the stylesheet from being added automaticly (form properties) and add it yourself
    Apr 13, 2010 @ 14:23
    Nick Collings
    Perfect thanks Tim,
    runat="server" in the <head> worked a treat.
