Im testing a rather large form, and its submitting fine (going to the thank you page). But..
- I've set up a workflow to send me and email - witch never arrive (my smtp in web.config is correct)?
- Umbraco client says "Showing 1 to 0 of 3 entries" when trying to view the entries, and nothing is showing, and export is empty..
Ive looked in UFRecords and UFRecordsXml, data shows up allright..
All form labels are dictionaty items (#label), and im using a lot of special characters such as 'æøå . %' in both dictionary names and the form name it self, might that be a problem?
The nightly build 1091 fixed the issue, but it still killed my xml because i had a dictionary item called "1367 XXX", which i reffered as "#1367 xxx" in contour, renaming the dictionary item helped..
Hope it helps somebody, otherwise nice talking to my self :-))))
Contour not showing entries..
Any known solutions?
/Anders
Might be the same issues as on: http://our.umbraco.org/forum/umbraco-pro/contour/7645-Contour-Entries-Missing
Any release date on a fix? :-)
just tested to be sure you guys didn make a fix.. not working in http://nightly.umbraco.org/Umbraco%20Contour/1.0.9.1/
Phew got it sorted... well sort of
