  • Christian Melbye 8 posts 28 karma points
    Apr 27, 2010 @ 13:23
    Christian Melbye
    Contour seems to have issues with Japanese characters in both captions and answers.
    Hi. I have some issues with contour which you might be able to help me sort out.
    Short summary of the issues:
    Issue 1.
    If a caption starts with a Japanese character ex: "" the submitted
    entries will not be listed backend. However the rendering and overall usage of
    the form frontend works fine.
    Issue 2:
    If an answer in a form contains a Japanese character  the character is not
    rendered out in the entries section. If you add an answer like this "my text "
     only "my text" is displayed and exported.
    Testsetup:
    Clean umbraco 4.0.3 install with runway.
    Installed contour 1.0.9.1 downloaded here: http://nightly.umbraco.org/Umbraco%20Contour/1.0.9.1/
    Machine running Windows 7 64bit with IIS
    Recreate issue 1:
    Create a form with one field and name the caption "". Include the form in
    one of the runway pages, and make submit some text to it. Head back to the form
    in the contour section and click entries. The entries view is now
     empty.
    However contour says that its "Showing 1 to 0 of 1 entries".
    The submitted e
    ntry is also present in the database
    Recreate issue 2:
    Create a form with one field and name the caption "A". Include the form in
    one of the runway pages, and submit the following text to the form "my text"
    Head back to the form in the contour section and click entries. Now you will
     see one entry.
    However it only displays "my text" and not "my text" as you
    would expect. In the
    database however the record seems to be stored correctly
    Please let me know if you need more information or there is some information i might have left out
    Apr 27, 2010 @ 13:28
    Christian Melbye
    Hmm. The formatting got a bit messed up. And the Japanese characters i pasted in disappeared. However it should work if you find a Japanese character here:
    http://en.wikipedia.org/wiki/Japanese_characters
  • Comment author was deleted
    Apr 27, 2010 @ 13:55
    Hi Christian, thanks for reporting the issue.
    I logged it in our issue tracker and we will look into for our next maintenance release.
    Apr 27, 2010 @ 14:03
    Christian Melbye
    Hi Tim. Thank you for your quick reply.
    Do you have any date planned for next maintenance release? This is kind of a show stopper on our current project, so it would be good to have a time frame to report back to our client.
    Apr 27, 2010 @ 14:08
    Will take a look this week and get back to you with a time frame
    May 03, 2010 @ 14:37
    Christian Melbye
    Hi Tim. Do you have any news on a time frame yet?
    May 11, 2010 @ 14:13
    Hi Christian,
    Currently testing the new maintanance release that fixes this issue.
