  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Apr 29, 2010 @ 12:51
    Tim
    Exporting a Contour Form To Another Installation
    Is the ability to export a contour form (and it's related data sources etc) in the same way that you can export document types etc as a package something that's on the horizon for Contour?
    If not, would I be right in thinking that it should just be a case of copying the relevant stuff from the database on one site to the database on the other? We've have a few standard forms that we'd like to be able to package up to set up on new sites as well, without having to manually recreate them each time.
    I'm toying with the idea of creating a dashboard package that creates a SQL script and generates a package for the form, including the script as an additional item to be run.
