  • Laurence Gillian 600 posts 1219 karma points
    Apr 29, 2010 @ 19:32
    Laurence Gillian
    Contours - Required Fields / Errors
    As discussed previously Contour injecting style="" into tags is not ideal. However it can be worked around.
    However what I've noticed is even when the validation is set to just appear at the top as a summary, these validation <span> tags are still being injected into the code regardless. They just don't get used.
    The injection of these <span> tags is causing issues in some webkit browsers, as they get interrupted into parent DIV's height. Plus its just a bit daft injecting them if they are not going to be used.
    Is this a known bug? Hope so! :)
    Thanks, Laurie x
    http://screencast.com/t/MDI0ZDliO
