Estou começando a usar o Umbraco e tenho um problema ao tentar visualizar as entradas de dados no contour, pois é solicitado uma autenticação do servidor onde o site esta hospedado, já tentei dar permissão as pastas e arquivos da aplicação e ainda sim o problema permanece. Tentei também utilizar o login e senha do sistema, do ftp, do banco de dados, e outros possível e nada resolve. alguém pode ajudar?
I'm starting to use the umbraco and I have a
problem trying to visualize the data entries in the contour, it is
called an authentication server where the site is hosted, I tried to
give permission to the folders and files the application and yet the
problem remains. I also tried to
use the login and password system, FTP, database, and other possible and
resolves nothing. can anyone
help?
problem, authentication in data entries
_____________________________________________________________________________________
I'm starting to use the umbraco and I have a problem trying to visualize the data entries in the contour, it is called an authentication server where the site is hosted, I tried to give permission to the folders and files the application and yet the problem remains. I also tried to use the login and password system, FTP, database, and other possible and resolves nothing. can anyone help?
this the print of the error...
http://www.shoppingpiedade.com.br/print_umbraco.jpg
