Hi i was just wondering if it was possible to do a manual upgrade from 1.0.7 to 1.0.9.1 as i didn't want to nuke db stuff.
Tom
can you just copy the hotfix over the top of the current install and it'll work?
Hi Tom,Yep, you should be able to copy the hotfix over the top. Just make sure you take a backup of the files you are overwriting before doing this.
Cheers,Neil
Manual upgrade from 1.0.7 to 1.0.9.1
Tom
Tom
Hi Tom,
Neil
