I have a little problem with the contour form. I have installed the package, and I everything seems fine in the backend. I can create a contact form, and test it from the backend, and it seems to work fine. But when I implement it like in the video tutorial, trough a rich text editor, it doesn't show up on the publieshed page (it does show up in the rich text-editor). If i enable out put escaping on the bodyText I can see that some of the code for the form is being rendered, but it stops after:
When using a rich-text-editor (RTE) for inserting the contactform, it needs a <form runat="server"> </form> around the macro.
For some reason I can't get it to include the <form runat="server"></form> in the RTE, so I'll include it in my template instead. Just did a quick test, and it works. Now I just need to rearange my template and XSL a little :)
Contactform not showing on page?
Hi :)
<?UMBRACO_MACRO formguid="b5be5804-ad54-45ae-bb6a-d39e43776cf3" macroAlias="umbracoContour.RenderForm" />
I am working on a test server, so the client can see the webpage as it progress. I suspect that it might be something with a license?
I have a license for triax-tdx.com and our IT-guy has configured our test-server to http://test.triax-tdx.com where it was triax.scanad.dk before.
(I don't know much about setting up servers I must admit)
I'm working on Umbraco v. 4.0.3. if thats any help :)
/Steven
Seems like I found a solution.
