  • Andrea Orimoto 16 posts 34 karma points
    Jun 09, 2010 @ 10:15
    Andrea Orimoto
    How to set default properties, settings and workflows on Form Creation
    Hello all,
    I'm using the nice template feature of contour, but I'm having a hard time figuring out how to do the following things:
    1. Fill in the fieldtype properties other than caption, mandatory and regex: for example tooltip. I've tried adding the tooltip attribute in the field xml element, but it doesn't work
    2. Assign fields to fieldsets: basically the template will create the template fields in one fieldset. is there any way to specify different fieldsets in the template?
    3. Set form settings on creation: e.g. mandatory field mark, required error message, invalid error message, etc...
    4. Set a specific workflow on form creation: all our forms need a specific workflow on submission. any way to specify this ini the template or somewhere else?
    all these tasks are manual and tedious at the moment (and error prone), would be great if there was a way to set defaults via template.
    is there any documentation regarding this hidden feature?
    thanks a lot
    andrea
