  • Tom 713 posts 954 karma points
    Jun 11, 2010 @ 05:33
    Tom
    Default Form Values
    Hi Guys,
    just wondering is it possible to pre-populate a text box with a default value in contour?
    I wanted to set some default values on a couple of different forms and couldn't work out how!
    Tom
  • Michael Lawrence 128 posts 200 karma points
    Jun 13, 2010 @ 21:24
    Michael Lawrence
    The only 2 ways I've found to accomplish this are to:
    1. Create your own field type that allows you to specify a default value.
    2. Use jQuery/JavaScript to set the values on the client side.
    I hope this helps!
