  • Thomas Kahn 602 posts 506 karma points
    Jun 14, 2010 @ 14:24
    Thomas Kahn
    XML-reference to a contour template?
    Hi!
    I'm looking for some sort of XML-reference for a contour template? Looking at UmbracoContour.config I see caption, type, mandatory and regex, but what if I want to add things like tooltip and required error message?
    Regards,
    Thomas Kahn
    Jun 18, 2010 @ 09:09
    Thomas Kahn
    Perhaps if I rephrase the question a bit.
    Does the default UmbracoContour.config-file contain all the available properties I can use when I want to create custom templates? The default templates are these:
    <templates>
    <template name="Contact form">
    <field caption="Name" type="3F92E01B-29E2-4a30-BF33-9DF5580ED52C" mandatory="true" />
    <field caption="Email" type="3F92E01B-29E2-4a30-BF33-9DF5580ED52C" mandatory="true" regex="\w+([-+.']\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*" />
    <field caption="Message" type="023F09AC-1445-4bcb-B8FA-AB49F33BD046" mandatory="true" />
    </template>
    <template name="Blog comment form">
    <field caption="Website" type="3F92E01B-29E2-4a30-BF33-9DF5580ED52C" mandatory="false" regex="(http|ftp|https):\/\/[\w\-_]+(\.[\w\-_]+)+([\w\-\.,@?^=%&amp;:/~\+#]*[\w\-\@?^=%&amp;/~\+#])?" />
    </template>
    </templates>
    Thanks in advance!
    /Thomas Kahn
  • Comment author was deleted
    Jun 28, 2010 @ 09:00
    Hi Thomas,
    Indeed, currently in the template you can set which fields you want and for a field you need to supply:
    Caption
    and
    Type
    Optional you can also supply
    Mandatory
    and
    Regex
    For the types here is an overview of the guids you can use:
    Checkbox: D5C0C390-AE9A-11DE-A69E-666455D89593
    DatePicker: F8B4C3B8-AF28-11DE-9DD8-EF5956D89593
    FileUpload: 84A17CF8-B711-46a6-9840-0E4A072AD000
    Password: FB37BC60-D41E-11DE-AEAE-37C155D8959
    Textarea: 023F09AC-1445-4bcb-B8FA-AB49F33BD046
    Textbox: 3F92E01B-29E2-4a30-BF33-9DF5580ED52C
    Regards,
    Tim
