  • Jack Moir 2 posts 72 karma points
    Aug 19, 2021 @ 09:00
    Jack Moir
    Umbraco Uno Hide page from top level nav
    Does anyone know how to create a standard page and hide it from public view in the top nav?
    I've created a contact form page which i want to only be accessible through a call to action however i cant seem to remove the page from the nav menu?
    Thanks J
    Aug 19, 2021 @ 12:28
    Alex Skrypnyk
    Hi Jack
    Umbraco has build-in protection functionality, so you can set up that the page will be hidden from not authenticated users.
    Another way to hide the page use "umbracoNaviHide" property on the page.
    Can you show the navigation code we can handle it together
    Alex
    Aug 19, 2021 @ 15:37
    Jack Moir
    Hi Alex
    Thanks for getting in touch, how do I show you the nav menu code?
    Cheers, Jack
    Aug 19, 2021 @ 17:28
    Alex Skrypnyk
    Hi Jack
    Go to settings -> templates -> find the needed template and needed view
    Are you familiar with Razor?
    Alex
  • kalspih 8 posts 78 karma points
    Aug 20, 2021 @ 08:38
    kalspih
    I am using the protection function, which is in the setting. Only authenticated users will be able to see the page.
