  • Rob Shaw 37 posts 170 karma points c-trib
    Nov 16, 2019 @ 15:36
    Rob Shaw
    Advice on injecting a localisation service for a custom class
    Hi All,
    I am creating a very simple custom required attribute which I have got working but it currently involves an anti-patter that I am trying to replace with an injected localisation service.
    using System.ComponentModel.DataAnnotations;
    using System.Web.Mvc;
    using Current = Umbraco.Web.Composing.Current;
    namespace MyUmbraco.DataAnnotations.Attributes
      public class UmbracoRequiredAttribute : RequiredAttribute, IClientValidatable
        public string DictionaryKey { get; set; } = "Validation.Required";
        public IEnumerable<ModelClientValidationRule> GetClientValidationRules(ModelMetadata metadata, ControllerContext context)
          var ErrorMessage = Current.UmbracoHelper.GetDictionaryValue(DictionaryKey);
          yield return new ModelClientValidationRequiredRule(ErrorMessage);
    As you can see I am using the Current.UmbracoHelper.GetDictionary() method which I know is a big "No No!". I would like to know if anyone has had experience with injecting the localisation service into a custom class?
    Rob
  • Paul Seal 524 posts 2890 karma points MVP 7x c-trib
    Nov 22, 2019 @ 00:03
    Paul Seal
    Try something like this.
    using System; using System.Collections.Generic; using System.ComponentModel.DataAnnotations; using System.Linq; using System.Text; using System.Threading.Tasks; using System.Web.Mvc; using Umbraco.Core.Composing; using Umbraco.Core.Services;
    namespace CleanBlog.Core
            public UmbracoRequiredAttribute(ILocalizationService localizationService)
                _localizationService = localizationService;
            private readonly ILocalizationService _localizationService;
                //you would need a way to know the current language, but for now we have the default one
                var defaultLanguageId = _localizationService.GetDefaultLanguageId();
                //this gets the item from the dictionary by using the key and then returns the translation for the default language.
                var ErrorMessage = _localizationService.GetDictionaryItemByKey(DictionaryKey).Translations.Where(x => x.LanguageId == defaultLanguageId).FirstOrDefault().Value;
    Cheers
    Paul
    Nov 22, 2019 @ 12:44
    Rob Shaw
    Hi Paul!
    Thanks for the reply, but it's a path I've been down already and I get the following issue:
    Attribute Issue Because we are injecting the ILocalizationService into the constructor it expects one to be passed in when I decorate Model properties 😅 Does anyone know a way around this? I've seen mentions of using Action Filters...but really hoping for another solution!
    BTW loving the Umbraco 8 videos you've been creating, keep up the good work!
    Cheers, Rob
