  • David 27 posts 127 karma points
    Nov 18, 2019 @ 12:02
    David
    How to check if a DateTime datatype is present or not?
    Hi all, I'm trying to write a condition where if a piece of content doesn't have a startDate, it will not display the date and only the title. However I can't seem how to figure out how to identify if a DateTime datatype is present or not. All the test examples I've used do not have startDate and are all showing as "01 January 0001"
    Any ideas?
      @foreach (var item in trainingCourses)
                if (item.IsNull(item.startDate))
                    <li>
                        <a href="@item.Url"><h3>@item.Name</h3></a>
                    </li>
                else
                    <li>
                        <p>@(item.GetPropertyValue<DateTime>("startDate").ToString("dd MMMM yyyy"))</p></a>
                    </li>
    David
  • Paul Griffiths 370 posts 1021 karma points
    Nov 20, 2019 @ 13:24
    Paul Griffiths
    Hi David,
    Does the following work:
        if (item.GetPropertyValue<DateTime>("startDate") == null || item.GetPropertyValue<DateTime>("startDate") == DateTime.MinValue)
            <li>
            </li>
        else
            <li>
                    <h3>@item.Name</h3>
                </a>
            </li>
    Paul
    Nov 21, 2019 @ 09:40
    David
    Hi Paul,
    Thanks for your reply. This looks to have done the trick :)
    Thank you!
    David
    Nov 21, 2019 @ 09:59
    Paul Griffiths
    Hi David,
    Great to hear that it helped :).
    Thanks Paul
