where the model is the details of the property you want to display: for example for a toggle this might look like :
vm.model = {
Alias = "autoSend",
Label = "On or Off",
Description = "Turn this thing on or off",
Value = vm.myValue,
View = "boolean",
Config =
{ "default", null }
The trick here is knowing what goes in the Config element as this can be different depending on the property type - there is not really a quick way to get this information at the moment, other than look at how it might be returned by Umbraco for a content item :
e.g if you look in chrome for network requests to GetById?id= you should be able to drill down, (under the variants tab) to something like this:
which will show you what Umbraco is passing into the Model value when it uses umb-property-editor.
in practice sometimes if you know what the type is you want it's often easier to call the directive for that. e.g for a checkbox this looks like :
<umb-control-group label="On or Off" description="Turn this thing on or off">
<umb-toggle checked="vm.myValue"
on-click="vm.myValue = !vm.myValue"
label-on="on"
label-off="off"></umb-toggle>
Umbraco Backoffice Angular Components
How can I use the umbraco umbproperty component in a custom backoffice dashboard?
I was looking on the documentation, but there isn't a helpfull example :(
Hi Enrique
it depends a bit on what property you wish to display through the property editor.
slightly better documentation would show this as
Thanks for your help.
I think umbraco would be great if they make a good documentation...😒
