  • iNETZO 136 posts 499 karma points c-trib
    Nov 24, 2019 @ 15:12
    iNETZO
    Error using Surfacecontroller with RouteTable.Routes.MapRoute
    I am trying to create a custom controller for handling media. I created a component with a custom route. My problem is that when I use a surface controller type controller, it gives the following error :
    [Exception: Failed to create an instance of controller type UmbracoMediaProtect.MediaProtect.Controllers.MediaProtectController (see inner exception).]
    When I use a controller of the type "Controler" the error does not occur but I want to add a [MemberAuthorize] attribute to the controller.
    Composer
    public class MediaProtectComposer : IUserComposer
            composition.Register<MediaProtectController>(Lifetime.Request);
            composition.Components().Append<MediaProtectComponent>();
    Component
    public class MediaProtectComponent : IComponent
        public void Initialize()
            RouteTable.Routes.RouteExistingFiles = true;
            RouteTable.Routes.MapRoute(
                "MediaProtect",
                "media/{id}/{file}",
                new
                    controller = "MediaProtect",
                    action = "Index",
                    id = UrlParameter.Optional,
                    file = UrlParameter.Optional
        public void Terminate()
    Controller [MemberAuthorize] public class MediaProtectController : Controller {
        public ActionResult Index(string id, string file)
            string mediaPath = $"/media/{id}/{file}";
            var media = Current.Services.MediaService.GetMediaByPath(mediaPath);
            if (media == null)
                return HttpNotFound();
            var fileStream = VirtualPathProvider.OpenFile(mediaPath);
            return new FileStreamResult(fileStream, MimeMapping.GetMimeMapping(file));
    Is it not possible to use a Surfacecontroller in combination with RouteTable.Routes.MapRoute?
    Best regards,
    iNETZO
  • Graham Davis 110 posts 376 karma points
    Nov 24, 2019 @ 21:26
    Graham Davis
    Try changing
    To
    public class MediaProtectController : Umbraco.Web.Mvc.SurfaceController
    Nov 24, 2019 @ 22:06
    iNETZO
    Thanks for your reply Graham! When i change it to a surfacecontroller, i get the error above:
    Nov 25, 2019 @ 22:58
    iNETZO
    Is there someone who used a surfacecontroller with a custom route succesfull in Umbraco 8?
    Nov 25, 2019 @ 23:42
