  • Andy Welch 3 posts 73 karma points
    Nov 26, 2019 @ 19:02
    Andy Welch
    Examine MultiSearcher and PDFIndex not working
    Hi, I've followed the docs and implemented PDFIndex and MultiSearcher.
    In the backend these are both healthy and return results.
    However, when I use them in code I get zero results from the PdfIndex either directly or via the MultiSearcher.
    This is the code which creates the PdfIndex and MultiSearcher...
    public void Initialize()
                //Get both the external and pdf index
                if (_examineManager.TryGetIndex(Constants.UmbracoIndexes.ExternalIndexName, out var externalIndex)
                    && _examineManager.TryGetIndex(PdfIndexConstants.PdfIndexName, out var pdfIndex))
                    //register a multi searcher for both of them
                    var multiSearcher = new MultiIndexSearcher("MultiSearcher", new IIndex[] { externalIndex, pdfIndex });
                    _examineManager.AddSearcher(multiSearcher);
    This is how I'm searching the PdfIndex directly...
    var textFields = new[]
                    "title", "description", "content", "bodyText", "location", "pageHeading", "subHeading",
                    "nodeName", "__NodeTypeAlias"
    if (ExamineManager.Instance.TryGetIndex("PDFIndex", out index))
                        searcher = index.GetSearcher(); ;
                        var query = searcher.CreateQuery("media").GroupedOr(textFields, searchQuery.Fuzzy(0.2f));
                        results = query.Execute();
    ...and this is a search against the MultiSearcher
    if (_searchPdf && ExamineManager.Instance.TryGetSearcher("MultiSearcher", out searcher))
                        var query = searcher.CreateQuery("media,content").GroupedOr(textFields, searchQuery/*.Fuzzy(0.2f)*/);
    I suspect I'm phrasing the search incorrectly. I'll continue to "fiddle" and strip the code down to minimum.
    Suggestions appreciated.
    Nov 26, 2019 @ 20:14
    Andy Welch
    Follow up on my experiments...
    Based on the fields I see in results when testing the PdfIndex in backoffice, I've tried the following textFields variation...
    var PdfTextFields = new[]
           "nodeName", "fileTextContent"
    still, sadly, with zero results.
    Nov 27, 2019 @ 10:33
    Ismail Mayat
    Andy,
    I have multi searcher over 3 indexes including pdfindex working. I suspect its your query, try getting rid of "media,content" bit also in your textfields you do not have fileTextContent which is where it stores the extracted content:
    Also can you do query.ToString() and report back the actual generated lucene query.
    Nov 27, 2019 @ 20:15
    Andy Welch
    Thanks for your help Ismail, it's really appreciated. I'll need a couple days to get back to you.
