  • Edgar Arroyo 19 posts 161 karma points
    Dec 02, 2019 @ 04:22
    Edgar Arroyo
    Umbraco 8.4-rc and global.asax
    I am using global.asax on Umbraco 8.4-rc (just updated) and it seems like it's not triggering "Session_Start" when I go to the website.
    protected void Session_Start(object sender, EventArgs e)
            Session["Date"] = DateTime.Today.Year.ToString() + "-" + DateTime.Today.Month.ToString() + "-" + DateTime.Today.Day.ToString();
            Session["Date1"] = DateTime.Today.Year.ToString() + "-" + DateTime.Today.Month.ToString() + "-" + DateTime.Today.Day.ToString();
            Session["Date2"] = DateTime.Today.Year.ToString() + "-" + DateTime.Today.Month.ToString() + "-" + DateTime.Today.Day.ToString();
            LoadList();
            GC.Collect();
    Sessions are not being set and function is not being called, reason why I suspect it's not calling "Session_Start"
    Dec 02, 2019 @ 04:28
    Edgar Arroyo
    Well, decided to "View Markup" and the update overwrote my global.asax
    I had to add "CodeBehind" and change the "Inherits" for it to work again.
    Should this be reported as a bug?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Dec 02, 2019 @ 10:07
    Mike Chambers
    Think the recommended approach is via composers now?
    https://our.umbraco.com/documentation/implementation/composing/
    Dec 02, 2019 @ 14:39
    Edgar Arroyo
    For what I need to do (set 6 sessions, 3 are simple, 3 are SQL query populated) I find it very easy to use "Session_Start"
    Would "Composing" be easier/simpler? Any examples of this simple task (setting sessions?) Maybe I will switch if I find it easier...
    Thanks.
