    Dec 05, 2019 @ 17:09
    Ismail Mayat
    Example code for property editor with custom prevalues in v8
    Can anyone point me to some sample code for property editor for v8 with prevalues? I am migrating similarity package v7 to v8. As it stands the save of prevalues is not working i get the following error:
    angular.js?cdv=1:15536 Possibly unhandled rejection: {"errorMsg":"Failed to retrieve data for data type id undefined","data":{"Message":"The request is invalid.","MessageDetail":"The parameters dictionary contains a null entry for parameter 'id' of non-nullable type 'System.Int32' for method 'Umbraco.Web.Models.ContentEditing.DataTypeDisplay GetById(Int32)' in 'Umbraco.Web.Editors.DataTypeController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter."},"status":400
    Part of my manifest for prevalues part looks like:
    prevalues: {
                fields: [
                        label: "Index",
                        description: "Index to search on",
                        key: "index",
                        view: "~/App_Plugins/Similarity/views/prevalueEditor/indexes.html",
                        validation: [
                                type: "Required"
                        label: "Number of docs",
                        description: "Maximum number of documents to return",
                        key: "maxNo",
                        view: "number",
                        validation: [
                                type: "Required"
    My controller for the custom prevalue editor looks like:
    angular.module("umbraco").controller("similarity.indexController",
        function ($scope, indexResource) {
            vm = this;
            indexResource.getAllIndexes().then(function(response) {
                vm.indexes = response.data;
    In my view i have:
    <div ng-controller="similarity.indexController as vm">
            <select ng-model="vm.value.index" class="umb-property-editor umb-dropdown" ng-options="index.IndexDirectory as index.IndexName for index in vm.indexes">
                <option>choose an index</option>
            </select>
    When i save i get errors. I suspect its something todo with
    The binding on the select?
    Anyone any suggestions?
