  • Levente Kosa 136 posts 352 karma points
    Dec 13, 2019 @ 13:15
    Levente Kosa
    Orderby with property value problem
    I would like to order children by a property value. Here are my structure: enter image description here
    What I want is to group by awardYear, so at the end under a year there would be many awardTitle etc. E.g:
    2019
    • award title 1
    • award title 2
    • award title 3
    2018
    • award title 4
    • award title 5
    2016
    • award title 6
    • award title 7
    • award title 8
    When I try like this...
    var awards = Model.Root().Children.Where(x => x.IsDocumentType("awards")).FirstOrDefault();
            foreach (var award in awards.Children.Where(x => x.IsVisible()).GroupBy(x => x.Value<string>("awardYear")).OrderByDescending(x => x.Value("awardYear")))
                var awardYear = award.Value("awardYear");
                var awardTitle = award.Value("awardTitle", fallback: Fallback.ToDefaultValue, defaultValue: award.Name);
                <div class="col-4">
                    <h4 class="text-uppercase">@awardYear</h4>
                    <p>@awardTitle, @awardYear</p>
    ...I got this error:
     'IGrouping<string, IPublishedContent>' does not contain a definition for 'Value' and the best extension method overload 'ValueExtensions.Value(HtmlHelper, string)' requires a receiver of type 'HtmlHelper'
    A little help would be great from somebody. Thanks!
  • Lars Heesakkers 38 posts 194 karma points
    Dec 13, 2019 @ 13:59
    Lars Heesakkers
    I think you need to use the "GetPropertyValue" instead of the "Value" function.
    Dec 13, 2019 @ 14:14
    Levente Kosa
    It wasn't that, but thanks
    Dec 13, 2019 @ 14:16
    Lars Heesakkers
    Could you share your solution for others to see in the future?
    Dec 13, 2019 @ 14:40
    Levente Kosa
    Sorry, there is no solution yet, I just answered that "GetPropertyValue" wasn't good. I got this message with it:
    'IPublishedContent' does not contain a definition for 'GetPropertyValue' and no accessible extension method 'GetPropertyValue' accepting a first argument of type 'IPublishedContent' could be found (are you missing a using directive or an assembly reference?)
    Dec 13, 2019 @ 14:42
    Lars Heesakkers
    Do you have the following using: @using Umbraco.Web at the top of your file?
    Dec 13, 2019 @ 15:02
    Levente Kosa
    I didn't have to, but I just figured out luckily. Here is the solution if somebody needs it:
    foreach (var award in awards.Children.Where(x => x.IsVisible()).OrderByDescending(x => x.Value("awardYear")).GroupBy(x => x.Value<string>("awardYear")))
            <h4 class="text-uppercase">@award.Key</h4>
            foreach (var item in award)
                var awardYear = item.Value("awardYear");
                var awardTitle = item.Value("awardTitle", fallback: Fallback.ToDefaultValue, defaultValue: item.Name);
                <div class="col-4">
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Dec 13, 2019 @ 15:05
    Marc Goodson
    101
    Hi Levente
    It's because you've used 'GroupBy'
    Your now looping through an IEnumerable<>
    instead of an IEnumerable
    so your award variable in the foreach loop is an IGrouping
            foreach (var awardGroup in awards.Children.Where(x => x.IsVisible()).GroupBy(x => x.Value<string>("awardYear")).OrderByDescending(x => x.Value("awardYear")))
    // you've grouped all of the awards for a particular year underneath the  awardYear - which is represented by the 'Key' of the group:
                var awardYear = awardGroup.Key;
       <div class="col-4">
    //now your 'group' will contain all the award's IPublishedContent items for that year so you can loop through these:
    @foreach (var award in awardGroups){
    if that makes sense, it's been a while since I've grouped anything...
    regards
    Marc
    Dec 13, 2019 @ 15:06
    Levente Kosa
    Thank you Mark, I just found it as well :)
