  • Matt 359 posts 842 karma points
    Dec 30, 2019 @ 10:43
    Matt
    Navigation with drop down
    Hi all,
    Hope we all had good Christmas,
    I'm working on a simple navigation, I've got the navigation working and if any child are under it will render these in a drop down.
    However what I want to do is be able to disable the dropdown even if there are child under the node.
    What I've done was created a true/false and when this is set to false I want the dropdown not to display. just the node.
    Here is my code;
        var selection = Umbraco.ContentAtRoot().FirstOrDefault()
        .Children()
        .Where(x => x.IsVisible());
    <div data-collapse="medium" data-animation="default" data-duration="400" class="navbar w-nav">
    <div class="w-container">
    <nav role="navigation" class="navmenu w-nav-menu">
        <a href="/" class="navlink w-nav-link">Home</a>
    @foreach (var item in selection)
        var children = item.Children(c => c.IsVisible()).ToArray();
        if (children.Any())
            <div data-hover="1" data-delay="0" class="w-dropdown">
                <div class="navlink w-dropdown-toggle">
                    <a href="@item.Url">
                    <div>@item.Name</div>
                    </a>
                <nav class="w-dropdown-list">
                @foreach (var child in children)
                        <a class="navlink w-dropdown-link" href="@child.Url" >@child.Name</a>
                </nav>
        else
            <a href="@item.Url" class="navlink w-nav-link">@item.Name</a>
         </nav>
            <div class="handburger w-nav-button">
              <div class="w-icon-nav-menu"></div>
    I thought I could just change this line
    if (children.Any())
    to
    if (!item.Value<bool>("disableDropdown") && (children.Any())
    But doesn't seem to be that simple.
    Any help would be great.
    Dec 31, 2019 @ 07:54
    Matt
    101
    Changed it to this and worked;
     if (!item.Value<bool>("disableDropdown") && item.Children != null && item.Children.Where(x => x.IsVisible()).Any())
