I have v8.3.0 site and i am running on azure and using deployment slots to deploy. I have multi index search with umbraco content index, examine pdf index and a custom index. When i deploy to slot all works fine. When i swap the slot the pdf index breaks and i cannot see indexes in backoffice and search errors.
Looking at the error in console in backoffice i have the following error:
n error has occurred.",
"ExceptionMessage":"Lock obtain timed out: SimpleFSLock@D:\home\site\wwwroot\App_Data\TEMP\ExamineIndexes\PDFIndex\write.lock","ExceptionType":"Lucene.Net.Store.LockObtainFailedException","StackTrace":"
at Lucene.Net.Store.Lock.Obtain(Int64 lockWaitTimeout) in d:\Lucene.Net\FullRepo\trunk\src\core\Store\Lock.cs:line 97\r\n at Examine.LuceneEngine.Directories.MultiIndexLock.Obtain(Int64 lockWaitTimeout)
in C:\projects\examine-qvx04\src\Examine\LuceneEngine\Directories\MultiIndexLock.cs:line 40\r\n
If i delete the pdf index and then touch the web.config indexes appear in backoffice and search works.
Azure deployment slot swap issue
Anyone seen this before?
Hitting similar issues did you get any further with this?
David,
I raised gold partner ticket with Umbraco support, one thing they suggested which has improved things but not completely solved,
https://github.com/umbraco/Umbraco-CMS/issues/5035#issuecomment-546136237
I followed:
I did not have the last one I added that and now its not happening as often. Although recently i have not been doing as many deploys on this site.
Regards
Ismail
