Running version 7.15.
My site was taken down by the below Lucene Corrupt Index error.
From the stack trace I don't believe it is related to any custom code.
Has anyone received this error and resolved it permanently?
By rebuilding the index again and restarting app pool the site began to function. The concern is it will occur again and cause another outage.
Hi Yakov, Thanks for your reply. Yes I did that to resolve the issue but am concerned it could happen again and I am trying to prevent it. Any ideas on what caused this?
Hi Ismail, I am hosting on prem, not load balanced.
I think it could be app pool related. We have two IIS sites pointing to the same source files. One site is public facing, no /umbraco access. The other is internal with /umbraco access.
Both sites were running their own app pools and I think this was causing the lock/corruption? Switching to run both under the same App pool seems to have resolved it for now.
Lucene Index Corrupt Exception crashes site
Hi all,
Running version 7.15. My site was taken down by the below Lucene Corrupt Index error. From the stack trace I don't believe it is related to any custom code. Has anyone received this error and resolved it permanently?
Thanks in advance for any help!
Did you try to reset umbarco cache and rebuild indexes?
sometimes custom data gathering code can be reason for it.
This happened again today. Took the whole front end of the site down as the pages refer to content held on the index - which is corrupt!
Anyone have this before?
Jonny,
How are you hosting? Are you load balancing?
That 2nd image missing lucene dll is really weird?
Have you ever done anything similar?
Thanks Jonny
Jonny,
Yes but one would have been elected as primary and the other as secondary. See https://our.umbraco.com/Documentation/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible-advanced-v7 you are not load balancing as such but its a similar situation in that one of them is for editing content and the other is for reading only
