I'm looking for solution for a timer which should work like this:
Editor select an option from a dropdown within a page, the timer starts. After 1 week time the page unpublish itself.
There is already a built-in option for scheduled (un)publishing. This can be found when going to the node you want to schedule and clicking on the arrow next to Save and Publish.
Next select the Schedule... option and set the publish/unpublish dates.
Is this what you are looking for or do you need something more specific?
Thank you for the quick answer.
I'm looking the same function, but make it automated.
So I have this dropdown with the following three options: Available, Reserved, Let
You select "Let", save the page and that's it.
1 week later the page unpublish itself.
It's basically the same, just less click for the editor. It's unnecessary because it will be always 1 week.
I haven't done a similar feature myself but I assume you can accomplish this using a custom implementation of a IComponentwhere you can hook in to the ContentService.Publishing event.
Recommendation for a timer
I'm looking for solution for a timer which should work like this: Editor select an option from a dropdown within a page, the timer starts. After 1 week time the page unpublish itself.
Hi Levente,
Save and Publish.Next select the
Schedule...option and set the publish/unpublish dates.Is this what you are looking for or do you need something more specific?
Best,
Hi Jeffrey,
Thank you for the quick answer. I'm looking the same function, but make it automated. So I have this dropdown with the following three options: Available, Reserved, Let
You select "Let", save the page and that's it. 1 week later the page unpublish itself.
Ahh.. clear!
IComponentwhere you can hook in to theContentService.Publishingevent.See this page on the documentation as well: https://our.umbraco.com/documentation/reference/events/contentservice-events
Let me know if you need some more help ;-)
Thank you for your help!
