Hi everyone,
I have a blog running, which works with a macro. Now I only wanted to add another small post overview, but this doesn't work.
Here is, what I have. First, this is the code which calls the 2 macros:
<section class="section align-left"> <div class="container col-sm-10"> @Umbraco.RenderMacro("latestBlogposts", new { numberOfPosts = Html.Raw(Umbraco.Field("noofposts").ToString()), startNodeId = Model.Content.Id }) </div> <div class="container col-sm-2"> @Umbraco.RenderMacro("latestBlogpostsmall", new { numberOfPosts1 = Html.Raw(Umbraco.Field("noofposts").ToString()), startNodeId1 = Model.Content.Id }) </div> </section>
This is the first macro, which is working:
@using ContentModels = Umbraco.Web.PublishedContentModels; @using Umbraco.Web; @inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var startNodeId = Model.MacroParameters["startNodeId"] != null ? Model.MacroParameters["startNodeId"] : Model.Content.Id; var numberOfPosts = 100; if (Model.MacroParameters["numberOfPosts"] != null) { int.TryParse((string)Model.MacroParameters["numberOfPosts"], out numberOfPosts); } } @if (startNodeId != null) { @* Get the starting page *@ var startNode = Umbraco.TypedContent(startNodeId); var blogposts = startNode.Children.OrderByDescending(x => x.CreateDate).Take(numberOfPosts); if (blogposts.Any()) { foreach (ContentModels.Blogpost post in blogposts) { <section class="section align-center" style="padding: 40px 0 10px;"> <div class="container"> <div class="col-sm-6 align-center img-column"> @if(post.BlogImage != null){ <a href="@post.Url"><img src="@post.BlogImage.Url" /></a> } </div> <div class="col-sm-6 align-left"> <article style="max-width: 480px;"> <h5>@post.PageTitle</h5> <small class="blogpost-date">@post.CreateDate.ToShortDateString()</small> <p>@post.Excerpt</p> <a href="@post.Url" class="btn btn-outline-clr" style="margin: 30px 0 0">Read more</a> </article> </div> </div> </section> } } }
This is the second macro, which is throwing a YSOD with the message:
Exception Details: System.ArgumentNullException: Value cannot be null. Parameter name: child
@using ContentModels = Umbraco.Web.PublishedContentModels; @using Umbraco.Web; @inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var startNodeId = Model.MacroParameters["startNodeId1"] != null ? Model.MacroParameters["startNodeId1"] : Model.Content.Id; var numberOfPosts = 100; if (Model.MacroParameters["numberOfPosts1"] != null) { int.TryParse((string)Model.MacroParameters["numberOfPosts1"], out numberOfPosts); } } @if (startNodeId != null) { @* Get the starting page *@ var startNode = Umbraco.TypedContent(startNodeId); var blogposts = startNode.Children.OrderByDescending(x => x.CreateDate).Take(numberOfPosts); if (blogposts.Any()) { foreach (ContentModels.Blogpost post in blogposts) { <section class="section align-center" style="padding: 0 !important;"> <div class="container" style="padding: 0 !important;"> <div class="align-left vl"> <article style="margin-bottom: 20px !important;"> <a href="@post.Url"><h6 style="margin: 0 !important;">@post.PageTitle</h6> <small class="blogpost-date">@post.CreateDate.ToShortDateString()</small></a> </article> </div> </div> </section> } } }
With this line being marked red:
When I use the working "latestBlogposts", I have 2 blogs next to each other. I would be happy to get a hint.
Thanks in advance, Simeon
Blog problem
Hi everyone,
