Hi, some media items randomly started to disappear from website, they are returned as null when they are requested from a view.
When we hit the rebuild memory cache button under settings in Umbraco we get an error message that the cache couldn't be triggered and this is the exception from the log:
at Umbraco.Web.PublishedCache.NuCache.ContentStore.AddTreeNodeLocked(ContentNode content, LinkedNode`1 parentLink) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 964
at Umbraco.Web.PublishedCache.NuCache.ContentStore.SetAll(IEnumerable`1 kits) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 711
at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.LoadMediaFromDatabaseLocked(IScope scope, Boolean onStartup) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 453
at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.NotifyLocked(IEnumerable`1 payloads, Boolean& anythingChanged) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 773
at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.Notify(JsonPayload[] payloads, Boolean& anythingChanged) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 749
at Umbraco.Web.Cache.MediaCacheRefresher.Refresh(JsonPayload[] payloads) in D:\a\1\s\src\Umbraco.Web\Cache\MediaCacheRefresher.cs:line 46
at Umbraco.Core.Sync.ServerMessengerBase.Deliver[TPayload](ICacheRefresher refresher, TPayload[] payload) in D:\a\1\s\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 295
at Umbraco.Web.Cache.DistributedCache.RefreshByPayload[TPayload](Guid refresherGuid, TPayload[] payload) in D:\a\1\s\src\Umbraco.Web\Cache\DistributedCache.cs:line 83
at Umbraco.Web.Cache.DistributedCacheExtensions.RefreshAllMediaCache(DistributedCache dc) in D:\a\1\s\src\Umbraco.Web\Cache\DistributedCacheExtensions.cs:line 163
at Umbraco.Web.Cache.DistributedCacheExtensions.RefreshAllPublishedSnapshot(DistributedCache dc) in D:\a\1\s\src\Umbraco.Web\Cache\DistributedCacheExtensions.cs:line 184
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_1.<GetExecutor>b__0(Object instance, Object[] methodParameters)
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
I had the same issue as Yakov, the path to some content and media nodes were broken. Problem was that the site had over 50 000 nodes.
I solved it by checking out the UmbracoCms from GitHub, connected it to my DB and ran the cache rebuild to find what nodes that caused the failure. Then i used the Umbraco services to move the node then moved it back to its original location, that fixed the path.
I have uSync installed, and we're using uSync Publisher, i dont think it's uSync that causing this.
In my situation I run update script for broken node and it solve the issue, we also have uSync installed. I try to monitor this issue to understand what couase to corruption.
NuCache fails to rebuild (Umbraco 8)
Any ideas? Umbraco version 8.2.2
It happens to me v8.5.3
Any idea?
please check items in DB
I found similar issue, that path, parentid and level is broken
// Herman
Thanks! i wrote an issue and you can see how i solved: https://github.com/umbraco/Umbraco-CMS/issues/7766
