  • Lasse 49 posts 161 karma points
    Jan 10, 2020 @ 09:05
    Lasse
    How to get to another view with a link and MVC
    I have a list of objects and I want to be able to select a specific one and view a different view with specific information regarding the object
    e.g. A list of bikes, but you want to see specific information regarding a bike, if it is broken or whatever.
    How do I go from one view to another, using a link (could be actionlink) and still using current layout using a controller and method. I have semi solved the issue, but when I open the link it opens a blank page with what I have, no navigation bar or anything.
    Any ideas?
    This is what i have in my current vieiw: <td>@Html.ActionLink("LinkText", "ControllerName", "MethodName", new { id = Something }, null)</td>
    Edit: I have correct controller, method name and ID in my view, this is just an example
    This is my result:
    Jan 10, 2020 @ 11:47
    Lasse
    Anyone got any ideas, i am running low on google search options to fix this
  • Graham Davis 110 posts 376 karma points
    Jan 13, 2020 @ 04:53
    Graham Davis
    When you click the link, is it supposed to go to a new page or load a div with a partial view on the current one?
    Jan 13, 2020 @ 07:00
    Lasse
    The ActionLink i have right now, is the only way i know of, to get a Call to action button / Linktext, it should open in a new page but within the same template.
    Jan 13, 2020 @ 14:00
    Graham Davis
    If I understand you correctly, you have some information in a database (about Bikes) that you want to load dynamically to a page using its id. If so, this is how am doing it for real estate listings. The way to do it is different between versions 7 and 8, so I am including code for both.
    Side Note..... you may have to create a custom route.
    *** UMBRACO 7  ***
    ***** The Controller *****
    using System.Globalization;
    using System.Web.Mvc;
    using Umbraco.Core.Models;
    using Umbraco.Web;
    using Umbraco.Web.Models;
    namespace zbdpm.Controllers
        //[OutputCache(NoStore = true,  Duration = 0)]
        public class PropertyController : Umbraco.Web.Mvc.SurfaceController
           public PropertyController()
                : this(UmbracoContext.Current)
            public PropertyController(UmbracoContext umbracoContext)
                : base(umbracoContext)
            private RenderModel CreateUmbracoModel()
                //use and existing node
                umbraco.NodeFactory.Node node = umbraco.uQuery.GetNode(-1).Children[0];
                IPublishedContent currentNode = Umbraco.TypedContent(node.Id);
                var model = new RenderModel(currentNode, CultureInfo.CurrentUICulture);
                //add an umbraco data token so the umbraco view engine executes
                RouteData.DataTokens["umbraco"] = model;
                return model;
            public ActionResult Index(string propertyID)
                PropertyDetails p = new PropertyDetails();
                p = z.zpmAPI(propertyID).jsonToEntity<PropertyDetails>();
                if (p._Property.PropertyID == null)
                    return View("/Views/Partials/Property/real-estate-not-found.cshtml", CreateUmbracoModel());
                else
                    ViewBag.PropertyDetails = p;//using viewbag to pass data through the umbraco model
                    return View("/Views/Partials/Property/real-estate.cshtml", CreateUmbracoModel());
            public ActionResult PropertyDetails(PropertyDetails p)
                return PartialView("~/Views/Partials/Property/_zProperty.cshtml", p);
    ***** real-estate.cshtml *****
    <div class="container-fluid">
        <div class="container">
            @Html.Action("PropertyDetails", "Property", (dbzBestPM.Models.PropertyDetails)ViewBag.PropertyDetails)
    ***** zProperty.cshtml *****
    @model dbzBestPM.Models.PropertyDetails
    <div id="Section-PropertyDetails">
        <div class="row">
            <div class="col-xs-12 col-sm-8 col-md-8 col-lg-8 col-xl-8">
                <h1>@Model._Property.StreetAddress.Trim()  @Model._Property.City.Trim(),  @Model._Property.State.Trim()   </h1>
        ******* PAGE HTML HERE *****
    Jan 13, 2020 @ 14:01
    Graham Davis
    *** UMBRACO 8  ***
    ***** Extended Surface Controller *****
    using System.Linq;
    public partial class zBestExtendedSurfaceController : Umbraco.Web.Mvc.SurfaceController
        public ContentModel CreateUmbracoModel()
            try
                //Borrow the Root for Creating Dynamic content pages
                return new ContentModel(Umbraco.ContentAtRoot().FirstOrDefault());
            catch (System.Exception ex)
                return null;
        public ContentModel CreateUmbracoModel(string pageName)
            try
                var cm = Umbraco.ContentQuery.Search(pageName)
                    .ToList()
                    .Where(x => x.Content.Name.ToLower() == pageName.ToLower())
                    .FirstOrDefault()
                    .Content;
                return new ContentModel(cm);
                return null;
    namespace zBestPM.Controllers
        public class PropertyController : zBestExtendedSurfaceController
                if (p == null)
                else
                    Session["PropertyInfo"]= p;//Using Session Variable to Pass data to page
                    return View("~/Views/PropertyInfo.cshtml", CreateUmbracoModel("real-estate"));//real-estate is defined in the umbraco backoffice
