Unhandled exception in AppDomain - read past EOF error in Lucene indexing
We've been having a problem with Lucene indexing for a while already.
Basically quite often when we try to publish a content the indexing just throws an error like this:
2020-01-13 22:22:38,068 [P36840/D2/TLucene Merge Thread #0] ERROR Umbraco.Core.UmbracoApplicationBase - Unhandled exception in AppDomain (terminating)
Lucene.Net.Index.MergePolicy+MergeException: Exception of type 'Lucene.Net.Index.MergePolicy+MergeException' was thrown. ---> System.IO.IOException: read past EOF
at Lucene.Net.Index.IndexWriter.HandleMergeException(Exception t, OneMerge merge)
at Lucene.Net.Index.IndexWriter.Merge(OneMerge merge)
at Lucene.Net.Index.ConcurrentMergeScheduler.DoMerge(OneMerge merge)
at Lucene.Net.Index.ConcurrentMergeScheduler.MergeThread.Run()
--- End of inner exception stack trace ---
at Lucene.Net.Index.ConcurrentMergeScheduler.HandleMergeException(Exception exc)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
We get Secure Connection Failed on the public site as the result, the content is being saved but not included in cache so it does not display on the website.
Then we are unable to access Examine Management dashboard to restart indexes.
The error sometime slooks like this too:
2019-12-30 14:49:14,895 [P18524/D2/T28] ERROR Umbraco.Core.UmbracoApplicationBase - Unhandled exception in AppDomain (terminating)
System.IO.IOException: Cannot overwrite: D:\Inetpub\vhosts\mysite.com\httpdocs\App_Data\TEMP\ExamineIndexes\Internal\Index\_pe.cfs
at Lucene.Net.Store.FSDirectory.InitOutput(String name)
at Lucene.Net.Store.SimpleFSDirectory.CreateOutput(String name)
at Lucene.Net.Index.CompoundFileWriter.Close()
at Lucene.Net.Index.DocumentsWriter.CreateCompoundFile(String segment)
at Lucene.Net.Index.IndexWriter.DoFlushInternal(Boolean flushDocStores, Boolean flushDeletes)
at Lucene.Net.Index.IndexWriter.DoFlush(Boolean flushDocStores, Boolean flushDeletes)
at Lucene.Net.Index.IndexWriter.PrepareCommit(IDictionary`2 commitUserData, Boolean internal_Renamed)
at Lucene.Net.Index.IndexWriter.Commit(IDictionary`2 commitUserData)
at Examine.LuceneEngine.Providers.LuceneIndexer.IndexCommiter.TimerRelease() in C:\projects\examine-qvx04\src\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1711
at Examine.LuceneEngine.Providers.LuceneIndexer.IndexCommiter.<ScheduleCommit>b__7_0(Object _) in C:\projects\examine-qvx04\src\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 1663
at System.Threading.TimerQueueTimer.CallCallbackInContext(Object state)
In such case publishing a content becomes practically ineffective.
Any idea what's the cause? And how to fix it? I can see the index becomes corrupted but why?
It normally happens when a member is updating their content via their management centre (which uses umbraco api) and we are doing some updates via umbraco CMS (not necessary the same content). But not exclusively - sometimes just happens when a member updates the site or we are only updating it via cms.
Obviously exceptions happen but it shouldn't take down the whole website.
I generally imagine though that if there is indexing issue or index crash or is corrupt this should restart the index, not take the site down?
We get
Secure Connection Failedon the public site as the result, the content is being saved but not included in cache so it does not display on the website.Then we are unable to access Examine Management dashboard to restart indexes.
I have checked several similar issues like these:
https://stackoverflow.com/questions/30468541/umbraco-indexing-error-filling-up-logs
https://issues.apache.org/jira/browse/LUCENENET-527 but none of them is our case - I can't see any 0kB segment files.
Anyone can help with this?
Just to add - rebuilding indexes does not work.
The site crashes even on minot CMS content updates or deletions.
This issue is still happening.
Also reported here: https://stackoverflow.com/questions/59725408/unhandled-exception-in-appdomain-read-past-eof-error-in-lucene-indexing
Did you solve this issue?
Alex
/Rune
Nope. It is still happening
