  • André van der Plas 18 posts 108 karma points
    Jan 17, 2020 @ 14:50
    André van der Plas
    Populate dropdowns with template values
    Hi, a question about Dropdown Data Type. Is it possible to dynamically populate a dropdown with values which are entered in a template in the Content section? For example, I have a template in which I enter data of persons who work for a company (name, surname, birthdate et cetera). Now in another template I want to use a dropdown in which I can choose the names op the persons entered in the other template. Not sure if I made clear what I want. I hope so :-)
    Thanks.
    André
  • Marc-André 63 posts 279 karma points
    Jan 17, 2020 @ 16:31
    Marc-André
    Hi André.
    I would rather use a Content Picker restricted by your persons parent node.
    Otherwise, I can be really complicated to populate a dropdown with values entered on other pages.
    Hope this helps!
    Jan 20, 2020 @ 16:00
    André van der Plas
    Hi Marc-André,
    I tried the Content Picker and it worked ok in most cases. There are situations in which I need to pick more than one item. The Content Picker is restricted to one. Is there a solution for this?
    Greetings,
    André
    Jan 20, 2020 @ 16:01
    Marc-André
    Yes!
    Use the MultiNode Treepicker instead!
    Jan 20, 2020 @ 16:05
    André van der Plas
    Thnx!!
    Greetings,
    André
    Jan 20, 2020 @ 08:11
    André van der Plas
    Thanks for the feedback. I will try and use the Content Picker.
    Greeting,
    André
  • Amir Khan 1289 posts 2746 karma points
    Jan 20, 2020 @ 19:23
    Amir Khan
    In addition to the MNTP, Nupickers is nice for this too as you can change the way it renders in the back office to show properties other than the name of the node (name and surname for example):
    https://our.umbraco.com/packages/backoffice-extensions/nupickers/
    And the v8 port is referenced here which I haven't used but googled :) https://our.umbraco.com/packages/backoffice-extensions/nupickers/questionssuggestions/96901-nupickers-port-to-v8
    Jan 21, 2020 @ 07:44
    André van der Plas
    Hi all,
    I tried the MultiNode Treepicker and it worked great. Thanks for the help.
    Greetings,
    André
