  • David Armitage 510 posts 2082 karma points
    Jan 25, 2020 @ 01:22
    David Armitage
    Umbraco 8 | How to display a Grid within Nested Content
    Hi Peeps,
    I have been having trouble displaying a Grid View inside nested content with Umbraco 8.
    I have done this 100ds of times with Umbraco 7 and never had any problems.
    In the backend there is no problem. I can add a Grid View to the nested content section an it seems to populate as expected.
    The trouble is when it comes to render i the frontend.
    So the usual code @Html.GetGridHtml("WHAT GOES HERE", "mainText", "bootstrap3-fluid")
    With Umbraco 7 I used to just pass the nested content section model which is IPublishedContent and it just works.
    The problem with Umbraco 8 is that the Grid is wanting an IPublishedContent and the nested content section model with Umbraco 8 is now IPublishedElement.
    Is their to get the Grid to either accept IPublishedElement or is there anyway to cast IPublishedElement into IPublishedContent?
    Thanks in advanced
    David
    Jan 25, 2020 @ 01:46
    David Armitage
    Hi Guys,
    So I figured this out. You can actually pass in IPublishedProperty instead of content.
    I couldn't see this for looking.
    Anyway if anyone has the same problem then the way I achieved this was.
    @Html.GetGridHtml(nestedContent.GetProperty("mainText"),"bootstrap3-fluid")
    Regards David
  • Charlene 1 post 71 karma points
    Sep 30, 2020 @ 14:08
    Charlene
    Thank you for this! It helped a ton
    Oct 01, 2020 @ 00:23
    David Armitage
    Glad I could help.
    Regards David
