I'm having a problem with Recpatcha 2 after just updating from forms 7.2.0 to 7.3.0. I complete the form and the recaptcha and then on submit it throws back the following validation error:
Rolling back to 7.2.0 seems to fix this issue although it's not ideal as there is a fix for a separate issue in 7.3.0 that the site needs.
7.3.0 Recaptcha 2 not working
Has anyone else ran into this?
This is running on Umbraco 7.15.3
Hi Mark
Are you using Umbraco Forms' ReCaptcha or third party package?
Thanks, Alex
It looks like something with the serverside logic of ReCaptcha. Did you add public and secret keys to the config file?
Hey,
It's just using the Recaptcha 2 field that comes with UmbracoForms. And I checked the keys are definitely in there and configured correctly.
It's definitely doing something weird server side but can't find out what. Wondering if it's something broken in the new release.
For now I've rolled back to 7.1.3.
Mark V
Wow, I posted the same issue at nearly the same time. Is this a possible bug, and if so has anyone logged or acknowledged it?
I'm not sure I'm in a position to easily downgrade.
Thanks, Jason
We also got issues after updating to 7.3 and 8.3 of forms. We downgraded it to 7.2.1 and 8.2.1 of forms. So we believe this is a product bug of forms.
Looks like they fixed it today literally!
7.3.1 (11 February 2020)
Recaptcha failing postbacks after confirming uses aren't robots
Good News!
Thanks, Jason
