I'm trying to get the Custom Property Editor's setting from within C#. I can find the custom property "attached" to a node using the following code, but not sure how then to get its Editor settings related to this instance of the Property Type?
Dave
var _umbracoHelper = new UmbracoHelper( UmbracoContext.Current );
var homeNode = _umbracoHelper.TypedContentAtRoot().FirstOrDefault();
var streamNode = homeNode.Descendants( node_alias ).FirstOrDefault();
// Trying to find the Stream Id from the Property Editor Settings/Config
foreach( var prop in streamNode.Properties )
var propType = streamNode.ContentType.GetPropertyType(prop.PropertyTypeAlias);
if( propType.PropertyEditorAlias == "Damibu.CustomEditor"){
//then do something here
Reading Custom Property Editor configuration settings from C#
Hi all,
Thanks Dave
