  • Levente Kosa 136 posts 352 karma points
    Feb 10, 2020 @ 15:28
    Levente Kosa
    The required anti-forgery cookie "__RequestVerificationToken" is not present.
    When debug is false in web.config I get this message on my website.
    <compilation defaultLanguage="c#" debug="false" batch="true" targetFramework="4.7.2" numRecompilesBeforeAppRestart="50" />
    Error: The required anti-forgery cookie "__RequestVerificationToken" is not present.
    Any idea, suggestion? I also have a membership login page before my website. It somehow connects, because without the login restriction everything is fine, even with debug=true value.
  • HeKampeon 2 posts 72 karma points
    Aug 31, 2020 @ 18:39
    HeKampeon
    Hi Levente,
    I'm facing this problem. Did you solve this?
    Regards
  • Dee 118 posts 338 karma points
    Sep 01, 2020 @ 08:37
    Dee
    Are you trying to submit a form or call a surface controller action? What is the context of this issue exactly and when does this popup?
    Sep 01, 2020 @ 16:07
    HeKampeon
    Thanks Levente,
    It was a surface controller but i already find the solution. In my case i had a CachedPartial with my login modal and when i change it to renderPartial this problem disapear.
  • Warren Harding 132 posts 275 karma points
    Mar 17, 2021 @ 07:12
    Warren Harding
    I'm getting this error on Umbraco 8 as well (8.11 and 8.12) debug true or false for compilation - same thing
    __RequestVerificationToken is being passed through in the query paramenters and if I comment out [ValidateAntiForgeryToken] in the SurfaceController action it works fine... but that's not ideal.
    Has anyone had any luck with this one?
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Mar 17, 2021 @ 07:41
    Dave Woestenborghs
    Hi Warren,
    Are you caching the rendering of the form somehow ? If so, than the verification token will be cached as well. Verification tokens have a limited lifetime.
    Dave
    Mar 17, 2021 @ 08:05
    Warren Harding
    Thanks Dave and no, there's no cache at all - the form is directly in the Umbraco View Page.
    Mar 17, 2021 @ 08:10
    Dave Woestenborghs
    Hi Warren,
    I just saw you mentioned query parameters. Are you sending the form with a POST or a GET request ?
    Dave
    Mar 17, 2021 @ 09:57
    Warren Harding
    something like this:
    using (Html.BeginUmbracoForm("Action", "Controller", null, new { @id = "someIdThingo", @class = "form-validation position-relative", @novalidate = "novalidate" }, FormMethod.Post))
        @Html.AntiForgeryToken()
        @Html.HiddenFor(x => formModel.Id)
    I've also created a test c# mvc project on 4.7.2 as well and that works fine. I copied over as much of the web.config as I could from Umbraco too.
    These views and controllers are essentially the same as working Umbraco 7 versions that have been moved over to Umbraco 8 projects which all have this issue.
    Mar 17, 2021 @ 11:06
    Dave Woestenborghs
    Hi Warren,
    Are you running your website under https or not ?
    That could problems with this config setting in the web.config
    <httpCookies requireSSL="true" />
    If that is set to true, and you are not running SSL than you have issues. And probably the other way around as well.
    Dave
    Mar 17, 2021 @ 11:41
    Warren Harding
    Thanks again - yep I have that... actually here's most of the relevant parts of the web.config
    enter image description here enter image description here enter image description here enter image description here
    Mar 17, 2021 @ 13:31
    Dave Woestenborghs
    Hi Warren,
    Could you disable the rewrite url to see if that is the issue ?
    Dave
    Mar 17, 2021 @ 22:31
    Warren Harding
    Tried commenting them out, reload, still the same result...
    Mar 18, 2021 @ 09:07
    Dave Woestenborghs
    Hi Warren,
    I'm running out of ideas here.
    Could you check if you view the page that the request verifcation is set ? Could be that something is blocking your cookie from being set.
    Dave
    Mar 18, 2021 @ 21:08
    Warren Harding
    Thanks Dave - me too! It's got me stuffed.. Yes, the __RequestVerificationToken is definitely there in the form elements in the front-end and it's being posted in the request parameters.
    Mar 19, 2021 @ 07:59
    Dave Woestenborghs
    Hi Warren,
    There should also be a cookie written, besides the hidden form field. Can you check that ?
    Dave
