  • Frank Polack 1 post 71 karma points notactivated
    Feb 11, 2020 @ 19:21
    Frank Polack
    upload cshtml file through macro help
    i have been asked to maintain an Umbrago site for a local high school. (http://collinshillsoccer.com) I have been able to make simple edits, but am having trouble with a page that displays the Soccer Team Rosters. When I try to edit directly, it says it is Rendered through a macro. I found a macro that shows a file called TeamRoster.cshtml. I have no idea how to get to that file so that I can make updates. I don't have access to the host server, only the Backoffice module. Would greatly appreciate any help please.
    Feb 11, 2020 @ 22:44
    Marc Goodson
    Hi Frank
    Have a look in the 'Developer' section of Umbraco... depending on which version of Umbraco 4 you are on, there will be a folder for 'Partial View Macro Files' and I think you'll find your implementation in there...
    Otherwise then I think you'll need to update on the server :-(
    regards
    Marc
