When building examine queries I often use Luke to test queries. For the first time I need to search on integer values and the queries are working via Examine but not in Luke. Does anyone have any idea why this may be?
For example this query works ok:
searcher.CreateQuery().RangeQuery<int>(fields, 4, 4, true, true)
Raw query logs to:
{ Category: , LuceneQuery: +(status:[4 TO 4]) }
However if I run it direct Luke I get no results (same StandardAnalyzer):
+(status:[4 TO 4])
Running umbraco 8. Custom index on data from a database, StandardAnalyzer.
Fields defined as integers:
new FieldDefinition("status", FieldDefinitionTypes.Integer),
Any thoughts appreciated
Answer found:
https://stackoverflow.com/questions/45516870/apache-lucene-6-queryparser-range-query-is-not-working-with-intpoint
Seems you simply can't run a numeric raw query as it always searches for terms. Shame as it would be really handy for testing/building queries.
Examine - searching Luke for integers
Raw query logs to:
Answer found:
