  • Craig100 1136 posts 2523 karma points c-trib
    Feb 12, 2020 @ 20:39
    Craig100
    "Cannot render a macro when there is no current PublishedContentRequest" API problem
    Umb V7.15.3
    I have a controller extending UmbracoApiController. It's purpose is to import a page from one site to another and it works absolutely fine except in one particular scenario, if there's a Macro (like an embedded form) in an RTE.
    The following code works fine if the RTE doesn't contain a macro. If it does, then it throws the exception. "Cannot render a macro when there is no current PublishedContentRequest." My code is:-
            returnArticle.bodyText = string.Empty;
            if(theArticle.HasValue("bodyText")) {
                try{
                    var theBodyText = theArticle.GetPropertyValue<string>("bodyText");
                    returnArticle.bodyText = theBodyText;
                } catch (Exception ex) {
                    returnArticle.errorMessage += "ArticleId: " + theArticle.Id + " BodyText Error:" + ex.Message;
    returnArticle is my own Model. theArticle is an IPublishedContent.
    This is deep in a controller, far far away from rendering anything. It should just be assigning the RTE's content into the string variable.
    There are quite a few questions in the forum about this but none have a solution. I'd really appreciate a steer even if not a solution.
    // Craig }
    Feb 14, 2020 @ 11:09
    Craig100
    Following a nudge from sjb101 on the Slack channel the answer was to refactor "theArticle" by pulling it using the Content Service so it was an IContent rather than an IPublishedContent. So the code is now:-
                if(theArticle.Properties["bodyText"].Value != null) {
                    try{
                        returnArticle.bodyText = (string)theArticle.Properties["bodyText"].Value;
    And works nicely thanks very much :)
    //Craig
