UmbracoModelsBuilder failed to generate code: Exception: Response status code does not indicate success (InternalServerError)
I'm having problems building the models for a v7 site using the Models Builder API and Visual Studio package. When attempting to generate the models I get the below exception:
UmbracoModelsBuilder: Starting v8.0.5 13/02/2020 11:30:11.
UmbracoModelsBuilder: UmbracoModelsBuilder failed to generate code: Exception: Response status code does not indicate success (InternalServerError)
{"Message":"An error has occurred.","ExceptionMessage":"Syntax error, ',' expected","ExceptionType":"Umbraco.ModelsBuilder.Building.CompilerException","StackTrace":" at Umbraco.ModelsBuilder.Building.Compiler.ThrowExceptionFromDiagnostic(String path, String code, Diagnostic diagnostic) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder\\Building\\Compiler.cs:line 161\r\n at Umbraco.ModelsBuilder.Building.Compiler.<>c__DisplayClass12_0.<GetCompilation>b__0(KeyValuePair`2 x) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder\\Building\\Compiler.cs:line 50\r\n at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()\r\n at System.Linq.Buffer`1..ctor(IEnumerable`1 source)\r\n at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)\r\n at Umbraco.ModelsBuilder.Building.Compiler.GetCompilation(String assemblyName, IDictionary`2 files, SyntaxTree[]& trees) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder\\Building\\Compiler.cs:line 46\r\n at Umbraco.ModelsBuilder.Building.CodeParser.Parse(IDictionary`2 files, IEnumerable`1 references) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder\\Building\\CodeParser.cs:line 38\r\n at Umbraco.ModelsBuilder.Api.ApiHelper.GetModels(String modelsNamespace, IDictionary`2 files) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder\\Api\\ApiHelper.cs:line 16\r\n at Umbraco.ModelsBuilder.Api.ModelsBuilderApiController.GetModels(GetModelsData data) in D:\\d\\Zbu ModelsBuilder-7\\Umbraco.ModelsBuilder.Api\\ModelsBuilderApiController.cs:line 65\r\n at lambda_method(Closure , Object , Object[] )\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)\r\n at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()"}
UmbracoModelsBuilder: at Umbraco.ModelsBuilder.Api.ApiClient.EnsureSuccess(HttpResponseMessage result)
at Umbraco.ModelsBuilder.Api.ApiClient.GetModels(Dictionary`2 ourFiles, String modelsNamespace)
at Umbraco.ModelsBuilder.CustomTool.CustomTool.UmbracoModelsBuilder.GenerateRaw(String wszInputFilePath, String wszDefaultNamespace, IntPtr[] rgbOutputFileContents, UInt32& pcbOutput, String& errMsg)
First of all, I'm not sure how/why it is reporting ModelsBuilder v8.0.5 because it's not installed. The version installed via Nuget is v3.0.10 which is the latest for v7, I've cleared out the bin directory and done a full rebuild to be sure and checked each package.config file.
The output window in Visual Studio offers no detail at all to help track down the issue so wondering if anyone else has had this and resolved it? The solution builds just fine but we need the models.
Any ideas?
Edit: I can change the Mode to LiveAppData and generate the models in Umbraco just fine so it looks like the tool for some reason failing.
First of all, I would check that all projects in your solution have the same and correct version of ModelsBuilder from Nuget. the same for any references to Umbraco dependencies.
Funnily enough I have returned to this solution and have the same problem, again! Shame I didn't remember to come back and report my solution last time.
So after 2 years I'm working in a feature for this Umb8 project and I'm having a very similar issue:
- Same error than Simon when trying to run ModelsBuilder custom tool
but additionally,
- When running the website locally, boot fails:
Do you guys remember how did you solve it or have any suggestions?
Checking on dependencies version numbers next, but all the Umbraco related packages have the same version for the different projects within the solution...
I have the following in
appsettings:The output window in Visual Studio offers no detail at all to help track down the issue so wondering if anyone else has had this and resolved it? The solution builds just fine but we need the models.
Any ideas?
LiveAppDataand generate the models in Umbraco just fine so it looks like the tool for some reason failing.Hi Simon, I have this problem as well. Did you find a solution?
I can't actually remember I'm afraid.
Update: I was able to solve my issues by deleting bin and obj folders. Nothing else was needed. I forgot to mention I upgraded from 8.0.1 to 8.1.0.
So after 2 years I'm working in a feature for this Umb8 project and I'm having a very similar issue: - Same error than Simon when trying to run ModelsBuilder custom tool but additionally, - When running the website locally, boot fails:
