CORS problem with API. HTTP OPTIONS call returns 405
I have added a WebAPI to my Umbraco 8 site, by subclassing UmbracoApiController. Calling the WebAPI using Postman works fine, but when calling it from an external web app it fails. I am getting problems with CORS in the browser. It says OPTIONS {myendpoint} 405 (Method Not Allowed) and Access to {myendpoint} has been blocked by CORS policy: Response to preflight request doesn't pass access control check
I have modified the web.config file to add the headers required by CORS ('Access-Control-Allow-Origin' and 'Access-Control-Request-Headers') and verified with Postman they are correct. In short:
HTTP POST {mysite}/umbraco/api/{mystuff} works fine and has correct CORS headers.
HTTP OPTIONS {mysite}/umbraco/api/{mystuff} fails with 405.
Found this code snippet on how to add CORS, but that code is for Umbraco 7 and doesn't even compile for Umbraco 8.
as well I tried adding custom class by registering enableCors
public static class WebApiConfig
public static void Register(HttpConfiguration config)
config.EnableCors(new EnableCorsAttribute("*", "", ""));
config.Routes.MapHttpRoute(
routeTemplate: "api/{controller}/{id}",
defaults: new { id = RouteParameter.Optional }
Also added a data notation over my umbraco api controller
[EnableCors("","","*",PreflightMaxAge =200)]
all of these couldn't help for sorry this issue getting me mad
Really this worked on azure only by enabling cors origin of the app service
itself , unfortunately we will pass azure for its expenses and move to smarter asp we deployed on it all get requests are working but remaining post request you can check it by submitting that form with any values open console tab finally thanks for your efforts.
Although the thread is about azure the processes followed are not azure specific. Either your umbraco setup is incorrect or the way you are calling your API is incorrect, one or the other. We successfully use cors in with an umbracoapi and another site calling it.
For in details clarification MR/Reddick
I have an app built with umbraco and act as umbraco API endpoint , on the other hand I have a vue app as frontend app let's head away vue app away it's not our matter . On building the backend app all APIs locally on postman and IIS website are working successfully even "calling it from another website on IIS" then after deployment on azure faced that mentioned issue of CORS preflight error but it's resolved by enabling CORS of azure app service in addition to applying https://piotrbach.com/umbracocms-enable-cors-requests-in-umbracoapicontroller .
Cuz of highly expenses on azure we had to move on to any other hosting vendor after trying SmarterAsp that issue has been encountered again even if applying the previous URL steps.
Eventually hope to find a reasonable cause for that.
UmbracoApiController. Calling the WebAPI using Postman works fine, but when calling it from an external web app it fails. I am getting problems with CORS in the browser. It saysOPTIONS {myendpoint} 405 (Method Not Allowed)andAccess to {myendpoint} has been blocked by CORS policy: Response to preflight request doesn't pass access control checkI have modified the web.config file to add the headers required by CORS ('Access-Control-Allow-Origin' and 'Access-Control-Request-Headers') and verified with Postman they are correct. In short:
HTTP POST {mysite}/umbraco/api/{mystuff}works fine and has correct CORS headers.HTTP OPTIONS {mysite}/umbraco/api/{mystuff}fails with 405.Found this code snippet on how to add CORS, but that code is for Umbraco 7 and doesn't even compile for Umbraco 8.
Any ideas?
Solved the problem!
Had to do two things.
[HttpOptions]header to my controller action.web.config
MyController.cs
Dear I tried that but not working
It may be your call that is the problem
Have read of this http://www.html5rocks.com/en/tutorials/cors/#toc-types-of-cors-requests
Really appreciated for your fast reply , the shared link is useful but I will share my web config
as well I tried adding custom class by registering enableCors public static class WebApiConfig { public static void Register(HttpConfiguration config) { config.EnableCors(new EnableCorsAttribute("*", "", ""));
Also added a data notation over my umbraco api controller [EnableCors("","","*",PreflightMaxAge =200)]
check this article too.
Really this worked on azure only by enabling cors origin of the app service itself , unfortunately we will pass azure for its expenses and move to smarter asp we deployed on it all get requests are working but remaining post request you can check it by submitting that form with any values open console tab finally thanks for your efforts.
http://testvue-001-site1.dtempurl.com/RatingForm
Would like to mention that local environment working successfully with no problem
How are you calling your local setup from an external domain?
If it isn't working on your server then it is likely an iOS problem if you say it works locally.
My local I meant with it, My IIS server website calling it from another site
Sorry, I'm not understanding what you are trying to say.
What works and what doesn't?
If you have umbraco set up in a local iis website and can call it from another site then it isn't a problem with umbraco.
If you have it set up on another server in iis and that fails then it is a server issue.
For in details clarification MR/Reddick I have an app built with umbraco and act as umbraco API endpoint , on the other hand I have a vue app as frontend app let's head away vue app away it's not our matter . On building the backend app all APIs locally on postman and IIS website are working successfully even "calling it from another website on IIS" then after deployment on azure faced that mentioned issue of CORS preflight error but it's resolved by enabling CORS of azure app service in addition to applying https://piotrbach.com/umbracocms-enable-cors-requests-in-umbracoapicontroller . Cuz of highly expenses on azure we had to move on to any other hosting vendor after trying SmarterAsp that issue has been encountered again even if applying the previous URL steps. Eventually hope to find a reasonable cause for that.
