  • Luke S. 5 posts 74 karma points
    Feb 21, 2020 @ 20:15
    Luke S.
    RTE formats style with more than 2 classes
    I would like to have a large bootstrap button as one of the options in the format dropdown in the RTE, which would have the following classes: btn btn-primary btn-lg. I have the style in the stylesheet I'm using for the RTE set as 'a.btn.btn-primary.btn-lg'. However, when I apply that style to some text, the classes get added as: btn btn-primary.btn-lg - note the period in between the last classes instead of a space. I have a different style without the btn-lg class, and that works fine. Is there some sort of limitation as to how many classes those format dropdown styles can have, or is this a bug?
    Mar 02, 2020 @ 19:41
    Luke S.
    Can anyone else reproduce this, or is it just me that's having this issue?
  • Marc Deschenes 5 posts 76 karma points
    Feb 03, 2021 @ 20:08
    Marc Deschenes
    ran into this as well.. late to the game, but if it helps anyone -
    This will output as you expect
    /**umb_name:Primary Button - Large*/
    a.btn.btn-primary btn-lg{
    It seems past the second selector, it just outputs whatever is there, so I just removed the period (class selector). Output:
    <a class="btn btn-primary btn-lg">xyz</a>
  • Edgar Rasquin 326 posts 925 karma points
    Jul 27, 2022 @ 12:23
    Edgar Rasquin
    Hi Marc,
    that works well in the frontend. But in the backend rteditor the button is not beeing formatted.
    Any ideas? Thanks
