I put Umbraco 8.5 into production and I have a speed problem.
I have these things set:
IIS 7
Idle Time Out 0
Start Mode AlwaysRunning
Recyclacion at 23:50
Umbraco
Umbraco.ModelsBuilder.ModelsMode to LiveAppData
What else needs to be set to make Umbraco "not sleep" and work fast?
I also have a problem with the first load lasting a few seconds (10 - 20s). Other requests go fast (a few ms).
But after some time the request again takes a long time. It's random.
Are you quering any content by using XPath? I have had some performance issues on the first request it does after a App Pool recycle. I fixed it by removing those queries and using the ContentCache instead.
I use XPath in some custom functions, but I also have this problem in BackOffice :/ or in other custom functions ( API ) where I don't have XPATH they have these problems too.
Try to debug it by using the built-in miniprofiler. Here you can see all the actions a page load triggers and how much time it needs to complete. You can activate this by enabeling it from the backoffice.
Production setup - speed problem
I put Umbraco 8.5 into production and I have a speed problem. I have these things set:
I also have a problem with the first load lasting a few seconds (10 - 20s). Other requests go fast (a few ms). But after some time the request again takes a long time. It's random.
Can you help me?
Well thank you.
-Joep
-Joep
This will be a problem because I have my own REST API controller. I don't use umbraco views on the frontend.
Can I implement / return miniprofiler data to my own functions (custom api rest controller - UmbracoApiController)?
