  • jpdel3000 7 posts 27 karma points
    Feb 26, 2020 @ 17:33
    jpdel3000
    Problems with object and definition of Where
    Hello guys! I'm kinda new to Umbraco, and here also, but i'm following a tutorial to make a begginers website, and I followed every step along the way. But unfortunatly, the video i'm seeing doesn't has this error, and I do.
    List<NavigationList> navList = null;
            var subPages = page.Children.Where("Visible");
    The error that appears is " 'object' does not contain a definition for 'Where' ".
    Is there a way to fix it?
    PS: It's for a dynamic Header with the pages
  • Joep 96 posts 698 karma points
    Feb 27, 2020 @ 07:43
    Joep
    Try using this Page.Children.Where(x => x.IsVisible)
    -Joep
    Feb 27, 2020 @ 09:02
    jpdel3000
    It didn't work, same error :(
    Feb 27, 2020 @ 09:19
    Joep
    Sorry it is IsVisible() forgot that it was a method.
    -Joep
    Feb 27, 2020 @ 09:22
    jpdel3000
    For what i've read, it is a problem on "using System.Linq" but i do have that on my project, just says it's unnecessary dont know why
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Feb 27, 2020 @ 09:25
    Kevin Jump
    I think you are following the same video as in this post.: https://our.umbraco.com/forum/using-umbraco-and-getting-started/101110-code-error
    Its quite a long thread but the basics are in this reply: https://our.umbraco.com/forum/using-umbraco-and-getting-started/101110-code-error#comment-317042
    Feb 27, 2020 @ 09:37
    jpdel3000
    Hi Kevin,
    The previous error dissapeared, but now i'm getting "Value cannot be null Parameter name: Collection", my code is as follows (as the video teaches me)
    public List<NavigationList> GetNavigationModel()
            int pageId = int.Parse(CurrentPage.Path.Split(',')[1]);
            IPublishedContent pageInfo = Umbraco.Content(pageId);
            var nav = new List<NavigationList>
                new NavigationList (new NavigationLinkInfo(pageInfo.Url,pageInfo.Name))
            nav.AddRange(GetSubNavigationList(pageInfo));
            return nav;
    The error says it's in the line that has:
    Feb 27, 2020 @ 09:41
    Kevin Jump
    That might be because there are no items in the navigation,
    On your GetSubNavigationList method i would change
    to
        List<NavigationList> navList = new List<NavigationList>();
    this will mean the list is always something even if it's empty. and that will stop the next bit throwing an error when there are no pages to put in the list.
    I've had a google, i think the main problem is the video you are looking at was for Umbraco 6/7 and in Umbraco 8 you can't do 'dynamics' anymore :( so anywhere where 'dynamic' is used the code is going to need to be re-written
    Feb 27, 2020 @ 09:46
    jpdel3000
    Is there any begginers tutorial for 8 then? because not knowing how to do things, is hard :/
