  • nickornotto 403 posts 907 karma points
    Feb 26, 2020 @ 20:17
    nickornotto
    How to supply ContentModel for a view as string in RenderMvcController from PublishedContentModel (ModelsBuilder auto-generated)
    I am trying to adopt SPA (react) + umbraco solution described here: https://github.com/systempioneer/React-Umbraco-Example/blob/master/UmbracoReactStarterKit/Controllers/ReactRoutesController.cs to Umbraco 8.
    The default controller is a controller of type RenderMvcController which expects a model of type ContentModel (former RenderModel in umbraco v7).
    The problem is that the supplied model when converting model to string is PublishedContentModel which is the auto-generated model by ModelsBuilder.
    I had to make a few changes to adopt the source code to Umbraco 8 but the resulting values are of the same type like in the base solution above.
    The ContentModel that needs to be returned to the view:
    public class MasterModel : ContentModel
        public MasterModel(IPublishedContent content) : base(content)
        public InitialState InitialState { get; set; }
    This is my controller:
    public class ReactRoutesController : ReactRenderMvcController
        public override ActionResult Index(ContentModel model)
            return View("Master", CreateMasterModel());
        private MasterModel CreateMasterModel()
            var home = Umbraco.ContentAtRoot().First();
            var viewResult = ViewFromContentId(CurrentPage.Id); // returns view with model of type PublishedContentModel
            var viewResultAsString = viewResult.RenderToString(); // this calls RenderToString() shown below
            var model = new MasterModel(CurrentPage)
                InitialState = new InitialState
                    content = GetContentPages(),
                    homeUrl = home.Url,
                    location = Request.Url.AbsolutePath,
                    currentContent = new InitialState.CurrentContent
                        Name = CurrentPage.Name,
                        Url = Request.Url.AbsolutePath,
                        Content = viewResultAsString
                    currentPageName = CurrentPage.Name
            return model;
    inheriting from:
    public class ReactRenderMvcController : RenderMvcController
        public ViewResult ViewFromContentId(int id)
            var result = Umbraco.ContentQuery.Content(id); // gets the current document type with doc type model
            var renderModel = ViewExtensions.CreateRenderModel(result, RouteData).Content;
            return View(renderModel.GetTemplateAlias(), renderModel);
    The extension which is supposed to render the string from the view:
    public static class ViewExtensions
        // https://stackoverflow.com/a/19208941
        public static string RenderToString(this ViewResult partialView)
            var httpContext = HttpContext.Current;
            if (httpContext == null)
                throw new NotSupportedException("An HTTP context is required to render the partial view to a string");
            var controllerName = httpContext.Request.RequestContext.RouteData.Values["controller"].ToString();
            var controller = (ControllerBase)ControllerBuilder.Current.GetControllerFactory().CreateController(httpContext.Request.RequestContext, controllerName);
            var controllerContext = new ControllerContext(httpContext.Request.RequestContext, controller);
            var view = ViewEngines.Engines.FindPartialView(controllerContext, partialView.ViewName).View;
            var sb = new StringBuilder();
            using (var sw = new StringWriter(sb))
                using (var tw = new HtmlTextWriter(sw))
                    var viewContext = new ViewContext(controllerContext, view, partialView.ViewData, partialView.TempData, tw);
                    view.Render(viewContext, tw); // <---- THIS IS WHERE THE ERROR OCCURS - I guess it's because the controller expects `ContentModel` while it is being supplied `PublishedContentModel` instead - partialView parameter has model of type `PublishedContentModel`
            return sb.ToString();
    The actual error says:
    Cannot bind source type Umbraco.Web.PublishedModels.Home to model type MyDomain.Models.MasterModel. The source is a ModelsBuilder type, but the view model is not.
    To be honest I don't know how this could work on the original version the solution is made for ( v.7.6.2). I tried to install it but getting an error on db installation and not able to run it. umbraco's RenderMvcController always expected RenderModel, not a PublishedContentModel.
