  • GianniDPC 14 posts 80 karma points
    Mar 05, 2020 @ 09:52
    GianniDPC
    Umbraco forms conditions using dictionary keys
    I'm trying to create a multilangual form using the umbraco forms package. I've found that it is possible to translate labels by using a # in front of the label and adding it to the dictionary.
    The current problem I am facing is that I can't use conditions anymore this way.
    For example I want to show an input field if the user select a checkbox from a checkboxlist (the labels are all translated ofcourse) but the conditional doesn't execute this way.
    Example:
    show this field if all of the following match: Type diploma is #test
