'PublishedPropertyBase' is inaccessible due to its protection level
Hi, I'm in the process of upgrading Umbraco from 7 to 8. One of the issue I've encountered is that the site being upgraded uses property editors that are no longer used. When I do the DB conversion it fails for this reason.
Because we the site is fairly large, my plan was to produce a report listing each node and all of the properties it uses with their propertyEditorAlias's listed alongside. Unfortunately I'm getting the following error... Can anyone help?
Severity Code Description Project File Line Suppression State
Error CS0122 'PublishedPropertyBase' is inaccessible due to its protection level ClickLearn.Cms C:\Source Code\ClickLearn.cms\ClickLearn.Cms\Views\SiteStats.cshtml 63 Active
Thank you!
Severity Code Description Project File Line Suppression State Error CS0122 'PublishedPropertyBase' is inaccessible due to its protection level ClickLearn.Cms C:\Source Code\ClickLearn.cms\ClickLearn.Cms\Views\SiteStats.cshtml 63 Active
