  • Tony Lorentzen 85 posts 174 karma points
    Mar 10, 2020 @ 10:59
    Tony Lorentzen
    Umbraco 8.3 index lock error
    Getting the dreaded "Cannot index queue items, the index is currently locked" in the LogViewer and when I go to "Settings"->"Examine Management" I get "Failed to retrieve indexer details" error. Anybody know what's up?
    Site is running on Unoeuro (Now Simply.com).
    Do I need to delete any temp files maybe?
    Mar 10, 2020 @ 11:04
    Tony Lorentzen
    I should add that I'm running a site with multiple domains and I've read somewhere that Umbraco 8 might have issues with that?
  • Martin Rud 261 posts 1022 karma points c-trib
    May 23, 2021 @ 12:55
    Martin Rud
    Hi Tony,
    I have the same problem, also on Simply.com hosting. Did you find a solution? In backend I can´t get to rebuild index since the Examine Management dashboard won´t load but only show this error:
    Server error: Contact administrator, see log for full details. Failed to retrieve indexer details
  • Keith 76 posts 242 karma points
    Nov 05, 2021 @ 16:02
    Keith
    Hi Martin,
    I have the same error now too. Did you ever find a solution?
    Nov 05, 2021 @ 22:21
    Martin Rud
    Same here: Have not found any solution, unfortunately.
    Nov 05, 2021 @ 16:46
    Tony Lorentzen
    I never found a solution for this. Also. nobody from the core team seemed interested in fixing this. Ended up I lost the client because they were dissatisfied with Umbraco and because I had recommended it to them. $15.000 down the drain.
    Nov 05, 2021 @ 23:23
    Keith
    Yikes. That sounds awful.
    It seems to me that there are multiple causes of this. Rebuilding the internal indexes worked for some people, but not for me.
    I deleted the entire wwwroot folder on my azure app service and deployed from source again. The problem went away.
    I have had other issues in the past that are solved by deleting the folder and deploying again. But notnsure if it's azures deployment scripts fault or umbracos fault.
  • Mac 1 post 71 karma points
    Jan 19, 2022 @ 00:42
    Mac
    Anyone found a solution to this problem, please? I am having the same issue on a multi site website.
  • Bjørn Nyborg 5 posts 73 karma points
    Jun 27, 2022 @ 11:29
    Bjørn Nyborg
    Same issue here!
    Usually fixed by deleting all indexes and restarting app-pool.
    But it keeps coming back. 🙃
