  • Andrew Unger 45 posts 148 karma points
    Mar 10, 2020 @ 19:53
    Andrew Unger
    'Umbraco.Web.PublishedContentModels.ProductDocuments' does not contain a definition for 'GetPropertyValue' error message
    I am not sure why I get this error- "'Umbraco.Web.PublishedContentModels.ProductDocuments' does not contain a definition for 'GetPropertyValue'". I have used the same set up for other nested content on this page and it worked. If you have any insights on what might be wrong I would appreciate it.
        Layout = "Master.cshtml";
        var node = Model.Content;
        var home = node.Site();
        var productML = home.Descendant("markets");
        var product = @CurrentPage.Parent().Descendants("product").First();
        @foreach(var stuff in product.Children.Where("Visible")){
                if (stuff.HasValue("relatedDocuments"))
                        foreach (var item in stuff.GetPropertyValue<IEnumerable<IPublishedContent>>("relatedDocuments"))
                            if (item.HasValue("documentFile") && item.HasValue("documentName"))
                                    var file = item.GetPropertyValue<IPublishedContent>("documentFile");
                                    <div class="boxspacenope">
                                    <div class="outline3">
                                        <div class="row">
                                            <div class="col s6 m6 l6" align="left">
                                                <div class="title3"><b>@item.GetPropertyValue("documentName")</b></div>
                                            <div class="col s3 m3 l3" align="center">
                                                <ul class="links">
                                                    <li>
                                                        <a href="@file.Url" target="_blank"><div class="underline">Download</div></a>
                                                    </li>
                                                </ul>
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Mar 11, 2020 @ 09:11
    Dave Woestenborghs
    Hi Andrew,
    I think this caused because you are mixing dynamic and strongly typed syntax for accessing content.
    I wrote a article several years ago describing the difference between the two : https://24days.in/umbraco-cms/2015/strongly-typed-vs-dynamic-content-access/
    So if you change this line :
    To this :
     var product = Model.Content.Parent().Descendants("product").First();
    Your code will probably work
    Dave
