  • Johannes Lantz 156 posts 840 karma points c-trib
    Mar 16, 2020 @ 11:01
    Johannes Lantz
    Using IPublishedContent in razor helper method
    Hello everyone!
    I noticed that I use a code snippet in my template files very often. So to minimze code duplication I would like to make razor helper method of it. I would like it take the current model as a parameter. So my plan in to put it in "App_Code" to make it avaible to all template files. But when I us the following code:
    @helper DoStuff(IPublishedContent model){
            //Do stuff
    I get the error message: "IPublishedContent could not be found found". I have tried to use some @using statements but I can't figure it out. Anything advice would help right now!
    Note: As of writing this, I noticed that I could use a partial view, passing in the model to get the result I want. But could always be useful to know for the future!
    Thanks!
    //Johannes
  • Aristotelis Pitaridis 84 posts 402 karma points
    Mar 16, 2020 @ 21:31
    I like extensions so I will show you how to do it using extensions. If you want to put your code in App_Code, create the following class in this folder.
    using System.Web.Mvc;
    using Umbraco.Core.Models.PublishedContent;
    public static class MyExtension
        public static MvcHtmlString GetTag(this IPublishedContent model)
            TagBuilder h1 = new TagBuilder("h1");
            h1.InnerHtml = model.Name;
            return MvcHtmlString.Create(h1.ToString());
        public static MvcHtmlString GetText(this IPublishedContent model)
            return MvcHtmlString.Create(model.Name);
    This class contains two extensions. The first generates an h1 tag and puts the page name inside, and the second returns just the name of the page. In order to use it you will have to type the following lines
    @Model.GetTag()
    @Model.GetText()
    I hope it helps.
    Mar 18, 2020 @ 08:07
    Johannes Lantz
    Hi Aristotelis!
    This is really useful! Thank you so much!
