[SOLVED] - Content nodes not visible in Front end but visible in backend (preview mode)
Hello, i have a problem with an Umbraco 7.5.7 site.
I copied and installed DB and website from a production environment to a staging one. But there are some contents that give me an error 404 in frontend.
The strange thing is that when I make a preview (in Umbraco Backend) of the same contents, I am able to see them. These nodes are children of a root node (named Blog) that is rooted under Home Node in my Umbraco Backend. I tried to republish this "Blog" node and its children, but i have not solved the problem.
How can I solve this issue?
Hi Paco,
It seems you have copied the site to staging but have not given enough permissions to AppData folder. AppData folder needs read/write permission.
I would suggest to add read/write permissions to media, views, scripts, css.
Hope this answers your query.
Stay Safe!
Shaishav
Hi Shaishav,
first of all, thanks for your suggestion. I've seen the App_Data permissions and I have set them to Read/Write, as you correctly suggest.
The problem was a domain conflict on this subnode, that I solved this morning with the help of my system admin :)
Now It works and blog posts are visible
Cheers, Paco
