  • Frans Lammers 57 posts 401 karma points c-trib
    Mar 24, 2020 @ 13:51
    Frans Lammers
    Surface controller calls GET instead of POST in submit
    In a project I have a form on a partial view that gets rendered through a surface-controller. The form is made using Html.BeginUmbracoForm("action", "controller"). When I click on the submit button I expect to be led to the POST-method, but everytime I return to the GET-method instead.
    Here's the view that includes the partial:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<ForgotPassword>
    @using Project.Core.Models
        Layout = "Master.cshtml";
    <!-- Page Title-->
    <div class="page-title">
        <div class="container">
            <div class="column">
                <h1>Forgot password</h1>
    <!-- Page Content-->
    <div class="container padding-bottom-3x mb-2">
        <div class="row">
            <div class="offset-md-3 col-md-6">
                @Html.Action("ForgotPasswordRenderForm", "ForgotPasswordSurface")
    The partial looks like:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<ForgotPasswordViewModel>
        using (Html.BeginUmbracoForm("ForgotPasswordPost", "ForgotPasswordSurface"))
            @Html.AntiForgeryToken()
                <div class="row justify-center">
                    <div class="col-lg-8 col-md-10">
                        <h2>Forgot your password?</h2>
                        <form class="card mt-4">
                            <div class="card-body">
                                <div class="form-group">
                                    @Html.LabelFor(m => m.Email)
                                    @Html.TextBoxFor(m => m.Email, new { @class = "form-control" })
                                    @Html.ValidationMessageFor(m => m.Email)
                            <div class="card-footer">
                                <button class="btn btn-primary" type="submit">Get New Password</button>
                        </form>
    And this is the Surfacecontroller:
      public class ForgotPasswordSurfaceController : SurfaceController {
            [ChildActionOnly]
            public ActionResult ForgotPasswordRenderForm()
                ForgotPasswordViewModel model = new ForgotPasswordViewModel();
                return PartialView("Profile/Forgotpassword", model);
            [HttpPost]
            [ValidateAntiForgeryToken]
            public ActionResult ForgotPasswordPost(ForgotPasswordViewModel model)
                if (ModelState.IsValid)
                     // send mail to reset password
                    TempData["Status"] = "success";
                    TempData["StatusMessage"] = "A mail is send to this email address to reset the password";
                    return CurrentUmbracoPage();
    Can anyone see what I am doing wrong here?
    thanks,
    Frans
  • Joep 96 posts 698 karma points
    Mar 24, 2020 @ 15:24
    Joep
    Have you tried adding a FormMethod to your form?
    using (Html.BeginUmbracoForm("ForgotPasswordPost", "ForgotPasswordSurface", FormMethod.Post)
    -Joep
    Mar 24, 2020 @ 15:29
    Frans Lammers
    Hi Joep,
    Yes, I have tried that. Unfortunately it made no difference.
    thanks,
    Frans
  • Nigel Wilson 945 posts 2077 karma points
    Mar 25, 2020 @ 00:36
    Nigel Wilson
    Hi Frans
    How about trying the following:
    @using (Html.BeginUmbracoForm<ForgotPasswordSurfaceController>("ForgotPasswordPost", null, new { @class = "form" }))
    Cheers
    Nigel
    Mar 25, 2020 @ 08:20
    Frans Lammers
    Hi Nigel,
    Thanks, this didn't work either.
    But I found the problem: I was using a theme made by somebody else for this site and when reading into the Html closer I found a really hidden extra form tag. A form within a form doesn't work so removing that was the solution. (make a note to myself: read all the external code you use very close)
    cheers,
    Frans
