  • iNETZO 136 posts 499 karma points c-trib
    Mar 30, 2020 @ 12:43
    iNETZO
    Long SQL waits on umbracoLock
    Since a two weeks where getting quite often long waits on our SQL server on this query:
    SELECT value
    FROM umbracoLock
    WHERE id=@0
    The waits can run up to +40 seconds. umbracoLock is a very small table with only 10 rows an 3 cols. What can be a reason gettings waits on this table?
    Best regards,
    iNETZO
  • Graham Davis 110 posts 376 karma points
    Mar 30, 2020 @ 15:51
    Graham Davis
    Try Using.....
    SELECT value FROM umbracoLock WITH (NOLOCK) WHERE id=@0
    Mar 30, 2020 @ 17:35
    iNETZO
    Thanks for your reply Graham. Unfortunately the query is coming from Umbraco itself, for example when document-, media- or member properties are saved, so it's not easy to modify it. Are there other Our-member who had the same issue on high traffic sites with members? We’re using Umbraco 8.2.2
    Mar 31, 2020 @ 02:16
    Graham Davis
    Sorry that did not work for you. Based on your reply, this may need to be a fix in a future upgrade.
